Johnson Water Pump Rebuild
1983 Johnson Model J8RTCA --- 7.5 hp
How is the drive shaft and gear shaft disconnected to remove the lower case ?
luther
Daviet
Re: Johnson Water Pump Rebuild
Remove the bolts holding on the lower on and I think it will drop down.
The drive shaft is splined into the powerhead and I think the shift shaft slips into a D shaped housing.
Thanks for the info.
The parts illustration I found on the internet shows a splined shaft.
I will try to dis-assemble it over the weekend.
Luther
