Johnson year?
phil.leblanc
Hi, I pick up this 6 HP Johnson from a neighbour. It has not been used in at least 5 years but was tuned up last time. New points, Plugs...<br />Can you tell me what year it is, the proper fuel/oil mix and the proper gear oil to use.<br />It has had very little use. Is there anything I should look out for. I have some experience with bigger outboards. Thanks for any info.<br />Model # CD25R<br />Serial # C578897
OBJ
Re: Johnson year?
That be a 1968 Phil.<br /><br />Fuel mix is 50:1.<br /><br />Gear lube, any good gear lube for none electric shift should do.
