Johnson15 add on charging system
crzhors
Howdy, what does it take to add on the charging system to a 2006 4stroke 15 Johnson ,ropestart tiller model? We need to keep a battery chargede for a bilge pump. Thanks....
tashasdaddy
Re: Johnson15 add on charging system
the cost and output, is not worth it. solar panel, or or charge the battery periodically. you would have to change a lot under the flywheel, and add a rectifier.
F_R
Battery Charging kit part number 5037558, $133.32 from a Johnson or Evinrude dealer. Installation requires flywheel removal etc.
