johson 75hp w/ powershift 2 controls
this is kinda crude as i dont know the year on the motor or controls but here goes, the powershift 2 has a tan wire through the lower hole, what is it for?
its not hooked up to anything, but should it be i just bought this boat and am gonna take it out sat, unless advised not to
thanks
Re: johson 75hp w/ powershift 2 controls
sorry the motor is the 75 hp stinger with i believe is the long shaft, not sure if its electric shift i am guessing not
jgriner
im not a mechanic but i have a generic parts repair manual only thing i see on remote that is brown/tan would be a trim gauge indicator, maybe your boat had a trim gauge indicator? but ask a pro here on the forums
see pics
but on the engine brown wire i think is a overheat alarm, maybe it runs through to the remote
anyway to find the year check this.
http://forums.iboats.com/showthread.php?t=365226
F_R
Tan wire is the sensor for the overheat warning horn. I have no idea why somebody extended it outside the control, unless they mounted an external horn.
EDIT: GREY wire is for a tachometer. Are you sure it isn't grey/discolored?
