I think a good visual inspection will help.
You will be able to see a rivet that might be leaking.....
Hmmmm it has a deck? Does it have a live-well? Those are normally my first suspicion to check.
How much of a leak? Gallons? Ounces?
I am just not a fan of filling the boat with any amount of water.
Decks removed, clean hull, apply Gluvit.
Now thats not so hard!!!
Seriously JGG, if you have everything out of the boat, you might as well fix it right. Get a helper and re bunk all the loose rivets. Than apply Gluvit. Two things about Gluvit, it is slooow to work in cold temps but it flows into and around rivets and seams & it is not UV resistant so you will have to paint/cover it after application. A 16' boat should only need 1 can. Good Luck
thats what im going to do. i bought jb weld. is gluvit better?
