jonson 9.9
Natebreck
Hey everyone quick question I have what I think is a 70s Jonson 9.9 sea hores and it needs a ring job would anyone know if it’s worth fixing a motor of that age
It is if you do it yourself.----But what is your motor doing / not doing ?----What trouble shooting have you done if any.-----Just putting rings in possibly worn grooves might be a mistake too.
F_R
What is the exact year of your 9.9? I certainly wouldn't spend that kind of money on a 1974-1976. Are you assuming it needs rings because it fouls plugs? Those years did that when new right out of the box.
Natebreck
It doesn’t have full comprehension and and only has half the speed that it use to any ideas ?
flyingscott
What is your compressio? Those motors run fine 90#s of compression. Running at 1/2 speed sounds like running on one cylinder.
Post a model # of post some pictures of the engine and powerhead.----No need to ASSUME it needs rings.-----Could be a blown head gasket . ----Some inspection on your part needs to be done.----Post your actual compression numbers.-----Statements like " good compression "----Or ---" it doesn't have full comprehension " ---just mean nothing to folks ( 1050 miles away ) trying to help you !!!
F_R
Probably running on one cylinder. Did I mention they fouled plugs?
Natebreck
Thanks yeah the compression test had low numbers in one and I wish I could send pictures I’ll have to send them at another time the motor is in upstate ny about 350 miles away
oldboat1
might want to wait for those pictures. Current info. is that there is a European mutation of Covid 19 here in NY.
Natebreck
Another quick question would a car battery Work to start a 30 horse motor or do I need a boat battery
oldboat1
Car battery will work. (Better if you plan to keep it charged/topped off, otherwise deep cycle a better choice.)
