fishhawk16
- Joined
- May 13, 2004
- 73
I have 1996 90HP Looper on a Crestliner Fishhawk 165 SC. Dry weight is about 900LBS.<br /><br />The ventalation plate sits level with bottom of the boat. <br /><br />When I got my boat it had an OMC 14x21 alum prop. Boat would turn around 4800rpm. Knowing that this was to low I had a 14x19 repaired (minor ding) and put that on the boat. RPM was now 5100rpm. Still not enough I purchased a 14x17 OMC alum. I now turn around 5200 wot with a speed of about 43mph (speedo not GPS).<br /><br />I then tried a brand new 13.25x15 Bombardier. This one had a different blade design than all the rest. With this prop I was turning 5900RPM wot with a speed of 42mph.<br /><br />All speeds are with the speedo - same load same day.<br />Motor fully trimed up <br />All props are OMC or Bombardier<br />All props are alum<br /><br />Questions<br />What is the max RPM range I can run the engine at with out damage? <br /><br />Any ideas as to why I jumped 700RPM with only a 2" pitch change?<br /><br />If I put on a 13.25x15 SS will my RPM change up or down significantly?<br /><br />Sorry for the long post
