FlyingBoat
- Joined
- Jul 3, 2009
- 2
This probably sounds like a hundred other posts on here, but I have not seen an identical scenario. I recently bought a 23' Larson DC230 SportCruiser, with 5.7 Merc, trim tabs, etc. It had a 14.5 x 19p aluminum prop. Performance was ok, cruised 33-35 at 3500 rpm, but only turned 4000 WOT. First answer, drop to a 14.5 x 17p, which I did. Should help the pickup for skiing and allow higher rpm, right?
Cruise speed about the same, maybe a little faster (35-37 @ 3500), still only turns 4200-4300 rpm WOT, but now the da@#d thing will not stay in the water, it porpoises something terrible!! Yes, I can crank the trim tabs down and stop it, but it feels like I am dragging a sea anchor. I cannot trim the drive up ANY at all or it gets worse! So, here I am driving around with my drive trimmed all the way down/in and trim tabs hanging out to keep the front end on the water.
Since the new prop did not increase the WOT to what I think it should be (4400-4600), I am wondering whether the 19p was the right prop, but something else is keeping the rpm down. Also wondering whether there is a technique (I am obviously newbie) to keep the porpoising down. As an unrelated issue (I think), it does seem to cavitate very easily with either prop. Either in a tight turn or while it is porpoising it can cavitate so I have to chop the power, allow it to regain, and then add again. Is there something wrong there? Would a large anti-cavitation plate help, or a "whale tail"? Would more weight in the boat help these issues?
Ideas welcome!!
Gene
1988 Larson DC 230 SportCruiser
Ideas welcome!!
Gene
