jumping tachometer needle on Merc 4 cyl
rcarden
Hello,
I have twin 1999 Mercruiser 4 cylinders. The starboard tachometer (Teleflex gauge) has started to act up. With the engine running fine, the tach needle starts to jump a bit, sometimes all the way to max...then it will return to normal if I thump the gauge.
Does anyone have any idea where to begin to look for the cause?
Thanks,
Robert
imported_TheMan
Re: jumping tachometer needle on Merc 4 cyl
I don't know that I've heard of twin 4 cylinder setup.. interesting.
Anyway, if "thumping" the gauge works, I would clean all the terminal connections and put some di-electric grease on them. If that fails, replacing the wiring and/or gauge.. Tach is probably grounding out somewhere..
tommays
The tack goes through the 10 pin motor plug
Mine has had the need to thump and it turned out to be a bad connection at the 10 pin plug (it is NOT as sealed as it looks;))
I used contact cleaner and Qtips to clean out the sockets and pins and they got pretty dirty
Tommays
rcarden
Tommays & The Man,
Just a quick Thanks for your help with my tachometer. I did as you both suggested and the problem is fixed.
I appreciate ya'll taking the time to help others out on this board.
I've saved $100's using this forum.
