jluchuk
- Joined
- May 20, 2008
- 43
I have a 2000 Larson with 5.0 GL PEFS engines with twin Duo prop drives. It has 2 analog gauges that indicate the out drive position. Should the gauges move smoothly as the drives are raised and lowered? They do show full down and full up (no limit controls on this model as far as I can determine) but tend to jump as the out drives are moved. Is this jumping normal? Is the sender the type that can be cleaned or do the senders have to be replaced? Can it be something else like corroded wires or connections?
Jerry
Jerry
