just a quik question about a 84 2hp evinrude
ajhmfic
where does the water come out at after it circulates through the motor and how can i check if it is getting good circulation? i don't know much about boat motors (obviously) lol. please help me if you can. thank you.
Vic.S
Re: just a quik question about a 84 2hp evinrude
The water leaves with the exhast, but you'd expect some droplets spray or mist from the relief hole on the leg as well.
You should be able to touch the cylinder head for a second or two but if it is too hot to touch or sizzles if water is splashed on it then it is overheating and probably needs a new pump impeller.
