Just bought a 90 hp yam 1999 2-stroke
BugEyes
Actually I bought a boat and it came with it.<br />I'd like to know if there is any known issues with this mill or anything else I should know about it.<br />I havn't even run it yet, bought the boat and motor on dry icy land and I'm now waiting for the ice to thaw on the water so that I can use it.<br />Gear oil have been changed and that's all I know.
WillyBWright
Re: Just bought a 90 hp yam 1999 2-stroke
Well, I guess when you're asking about known problems, no news is good news. :) Good motors, reliable, not the strongest 90 of the time, but still nice. I rebuild the water pump, change the sparkplugs, and change the gearlube on used motors I buy. Sounds like the gearlube has been handled. It's also a good idea to pull the prop and check for fishline on the shaft that can damage the seal.
BugEyes
Thank's<br /><br />Will rebuild the pump just to know what is there.<br />No marks on the prop or lower unit to indicate bottom contact.<br />Will put in a fresh set of plugs and keep these as backup.<br />Checked under the cover for signs of overheat but found non.<br />Ordered the Clymer manual today so that I can service it properly.
