I just bought a 1997 Crestliner tournament 1750 aluminum bass boat. The boat is a tad over 17' long and is a v-hull. I think max HP is 140. It has a 1996 Johnson 4 cyl 115hp motor with a 14 x 19 aluminum prop. According to the web the hull weight of my boat weighs roughly 1150 pounds.
I took it out for a test run yesterday with about 1/4 tank of gas, two batteries and not much else. Two other guys came with me. We all weigh about 185 pounds each. I could not get the boat past 4500 rpm and that was achieved when I had the trim just right. Not sure of the speed but it seemed rather slow around 35 mph. The motor ran fine so I doubt that is causing my issues. Hole shot sucked as well.
I plan on raising the motor a hole or two and see if that helps. I also plan on upgrading the old "light" 12v motorguide TM with a heavy Minn Kota Maxxum 24 volt motor so that swap is going to add at least 100 pounds to the boat. Most of the time I will only have one passenger so with the new trolling motor and extra battery as well fishing tackle, cooler, and more gas in the tank the boat will be heavier then this last test run.
If I can't get the speed in the low to mid 40's i'm gonna sell this sucker. I remember my FIL had a 1993 17' Ranger with a 115 carbed Merc that would do 52 mph.
So I need a new prop but i'm unsure of the pitch and diameter I should get. I will most likely go with a SS prop. Help!!!!
