I just bought an '87 Baja Sunsport 196 with a 5.7L OMC Cobra I/O setup. This is my first boat and I have a couple questions. I was an auto mechanic for several years and consider myself mechanically inclined, so I plan on wrenching on this thing myself.
That being said, I know next to nothing about outdrives, so I am looking for a good service manual. I've seen a few suggestions that the OEM manuals are the only good ones. I'm assuming the aftermarket ones are like Chilton's manuals for cars; basically worthless. I followed someone's advice to check eBay, but couldn't find an OMC service manual for my '87. However, I did find a few '88 and '89 OEM ones. Can I use a manual for an '88-'89, or were there a lot of changes between the years?
Also, the only problem I am currently experiencing is a slight vibration when at full steering lock or when I have the drive tilted. If the drive is down and I keep it in the "trim" range on the gauge, there is no vibration (unless I turn sharply). Is this some sort of U-joint problem? How difficult is something like this to repair? Is it something I need to address immediately, or can I use the boat a couple more times and fix it this winter? Again, pardon my ignorance, but I am new to this.
I can tell you that after only having the boat out one time so far, I am hooked! I am very pleased with my Baja and plan on keeping it for a very long time. Any help is greatly appreciated!
