I have an 86 150 hp blackmax. Just changed the impeller. I tested it on the muffs and the stream from the tell tale hole is not as good as the older impeller. Will it have a better stream if the motor is in the water as opposed to being hooked up the muffs?
Another question, does the thermostat dictate how much water comes out of the tell tale hole?
