Just finished rebuild, winterizing question for this rebuilt
boater83
Just finished rebuilding the 115hp Ocean Runner V4 60 degree engine. Starts right up and idles fine. Question is do I need any special winterizing needed for this newly rebuilt engine ? I won't get a chance to break it in since winter is here, can I just spray fogging oil into the carbs and change the gear oil, or should I do add else to this newly rebuilt.
I'm worry about the oil goo buildups once spring hits due to the rich mixture .
Thanks.
Re: Just finished rebuild, winterizing question for this rebuilt
Ayuh,.... I'd change the lower gear oil, just in case water snuck in there....
As fer Foggin',... Personally, with 'bout 3 months or so til start up,...
I wouldn't....
Much longer than that, ya, I'd pickle it....
Ya probably ran that Rich mix fer testin' didn't ya,..??
That'll extra oil it,....
That's how some of the Efi, I/Os are mothballed, mixed gas in the fuel filter, 'n run it...
nwcove
jmo.....but id run a bit of premix with fuel stabilizer through it, then fog it till it stalls. why take any chance with your fresh rebuild?
boater83
I'm thinking the same. Just wasn't sure its a good idea to fog a newly rebuilt since its not properly broken in yet. This Saturday will be in the high 40s, I'll fog it it until it dies then.
