Just for starters... This has to be the wrong prop right?
Boester
Hi all... Great site and I've been researching a ton so I know I don't have all the "proper" info for you yet,. That said I am hoping to just confirm I believe my boat came with totally the wrong prop.
? 2007 Maxum 1800SR3
? 4.3L MPI Alpha 1
? Bravo 1 15.23x24 Prop
From day one this boat has taken FOREVER to reach plane while staring at the sky, and naturally it can?t pull a single skier out of deep water that weighs more than 160lbs to well ? and not me at all! Naturally, once on a plane and cruising it goes well and can reach a top speed of nearly 54-55 MPH.
From my research, this 24p Prop just seems SOOOO wrong. Am I finally seeing the light? I see a High Five 22 or 23 in my future immediately.
Thanks!
jimmbo
Re: Just for starters... This has to be the wrong prop right?
Welcome to iboats
What rpms are you getting?
Boester
Welcome to iboats
Hi jimmbo and thanks! My wife is from Edmonton btw! Anyway, it's been a slow start to our summer here in Seattle and I don't have that yet - plan on getting the boat wet tomorrow and will get that more accurate data.
Husker-Q
my 18.5 ft sea ray with 4.3l carb came with a 3 blade 23 p prop. I changed out to a 4 blade 21p prop and have been very happy with it. It can pull me (235 lb) out on 2 skis (I dont know how to single ski so have never tried it). I went with the Solaris alum purchased right here on iboats. I also installed SX smart tabs, for porpoising, but that may be helping my hole shot too.
steelespike
typical casual prop for speed in setups like yours is a 23" pitch, not necessarily good for skiing.
When you get us your numbers;light load,prop size, wot rpm and speed by gps. We can tell better if your setup works and
what may be needed.Your pin the right track reducing p[itch but I feel a high 5 is extreme.
Sherminator
sounds like you are WAY over propped! id give a 19p a go.
