JasonJ
- Joined
- Aug 20, 2001
- 4,163
So I have a add in the paper trying to sell off all of my excess outboards, and I had a guy come and trade me a 64 'rude 9.5 for a 56 15 horse parts motor I had. He said it ran last year, I figured as long as it turned and had compression I would be okay.<br /><br />I hooked up a gas tank and after a few pulls it ran. It was running rough, but running. I fiddled with the low speed and got it to idle. After about ten minutes it would start to miss and cut out, but kept running. It seemed like a coil issue so I swapped a set of new coils in that I had laying around, but that did not change the cutting out.<br /><br />Sometimes it would run great, and then it would start running bad and then run great. I pulled the carb, but it was not dirty at all. Kind of baffling, but this seems to happen with every OMC motor I get ahold of. Eventually I get them to run good with fiddling. <br /><br />My intent is to use it as a kicker after repainting it in updated white with modern decals, since it weighs the same as my 57 5.5 horse (I weighed them both, they are 60 lbs). Also, I assume it is 50:1. Any insight on the mysterious on again off again missing and cutting out would be appreciated...
