Re: just got aboat today...has a force i have a couple of Q's about it
It might have the same leg and a Merc ignition system, but that's where the similarity will end. The powerhead is totally different from a Merc. Closer to a Chrysler. ELPT=Electric start, Longshaft, Power Trim/Tilt.<br /><br />Never run the motor without supplying water to the water pump. It has to be in the water, or you can get a set of muffs to connect a garden hose. Always mix oil into the gas at a rate of 16oz/6gal. No matter how tempting it is and no matter how many other people you see do it, DON'T START THE MOTOR ON THE RAMP BEFORE LAUNCHING. The water pump is damaged in as little as 10 seconds.
