Re: Just painted the hull- can I wax now?
Interlux sez:<br />Do not apply heavy coats as this will affect dry through.
Failure to follow proper dry times carefully will cause improper drying, wrinkling and loss of adhesion. Avoid painting in direct sunlight. Product temperature should be minimum 10°C/
50°F and maximum 29°C
/85°F. Ambient temperature should be minimum 10°C/50°F and maximum 35°C
/95°F. Substrate temperature should be minimum 10°C/50°F and maximum 29°C/85°F.<br />-------------------------------------------------- <br />You painted the boat at the bottom of the suggested temp. I don't think [my opinion]that there has been sufficient time for the paint to harden. Pick up the phone and call one of their distributors listed on the net and get expert advise. Since it is black, putting in the water to quick could cause it to blush.
