glennj3
- Joined
- Sep 6, 2011
- 381
Hi everyone,
Stuck my neck out some here, auction, I won the bid. Don't know much about them other than the pictures. Came from a government auction, plan to pick it up tomorrow. $760.00
Items, one mercruiser 470 engine, all in tact, still connected to the outdrive ( looks like they cut through the transom and removed them)! The 470 and the 170 are in fact one in the same, 170 HP?
Looks like nothing was removed other than enough to take the engine out, has the shifter and cables, prop, outdrive, engine with carb, starter, heat exchanger, hydraulic lines to the outdrive. It all looks good other than some rust around the top of the carb, no flame arrester seen. I see a prop # 992005, best I can see, would this have anything to do with the pitch?
Anyhow, would like some advice on how to start checking this item out.
Thought I would pull the plugs, check the oil for color, water contamination etc. See if I can turn the engine over with a wrench, maybe check the compressions if she does in fact turn over.
Check the outdrive oil for contamination, see if it changes gears, maybe go ahead and check the water impeller, see if it is in tact. The prop is black which means it is aluminum I think, paint is not worn off much at all no barnacles etc on the outdrive.
If all this checks out good, maybe sit the engine up, clean the carburetor, put some gas in her and hit the starter with power, see if she turns over, fires, cranks etc.
Was not trying to run on about this but I am just a little excited and can't wait to get it home to start checking her out.
This is the same engine and outdrive I have in my boat.
What will I do with it? Don't know for sure. Never hurts to have spare parts, or sell it!
Thanks,
Glenn
Thanks,
Glenn
