Just read and lost recipie for best broiled or pan fried steak, grrrr......
ezbtr
Was saying get cast iron pan as hot as possible, open windows, sear for 3-4 mins a side. Two old buddies coming over tomorrow night, haven't seen one in 25 yrs. Not sure what kind of steaks we doing, buddy bringing over. Will have baked beans, potatoes, salad and apple pie too :)
nwcove
Re: Just read and lost recipie for best broiled or pan fried steak, grrrr......
heres how i do it when its to cold to flash up the bbq. dont get the pan as hot as possible, just hot enough to get the oil to smoke a bit...not catch fire! ( as always , its very important to allow the meat to reach room temp before cooking)
How to Cook a Steak in a Pan - Gordon Ramsay - YouTube
ehenry
Preheat oven to 425 degrees. Cooking 6 to 8 oz filets, Season all sides with pepper, heat cast iron skillet over medium high heat with a teaspoon of oil (more oil if large skillet) to the point of amost smoking the oil and put filets in skillet. Sear filets about 2 minutes per side. Take a sweet onion, slice it as thin as you can and put in skillet over filets when you flip them. After two minutes on the 2nd side put in 425 degree oven 7 to 8 minutes for a medium rare filet.
put wood in the grill, light and grab a beer
when beer is done, put potatoes, vegies, etc on the grill. grab another beer.
when half the beer is gone, flip everything on the grill
when beer is empty, put steaks on the grill. after 2 minutes, flip.
when beer is half empty, pull everything and put on a serving tray.
My Chili takes about 8 beers. my smoked turkey takes about 12 and my smoked pork shoulder takes 18
64osby
I once new a guy that measured driving time in beers.
You saw and lost the recipe, any chance it would be in the history of the computer.
roscoe
Dad did that for years. A 6 pack would get him about 200 miles.
He was darn thirsty when he pulled in the driveway at 230 miles.
Uncle needed a quart to get him home, 40 miles.
ezbtr
good grief, I like my Sierra Nevada but not that much!!! :)
colbyt
It does not have to be cast iron, any heavy pan will work. Get the pan hot enough to make a drop of water dance. As for oil wet a paper towel and rub it around the cool dry pan before you start. 3-4 minutes is for a thick cut of 1" or more. You will never get well done steak that is fit to eat with this method.
redneck joe
Was dinner Monday? How did it go?
I always use cast iron if using a pan. A heavy skillet will work, but if you got granny's old Lodge use it and you wont have to use any oil.
Couple basics:
God did not intend for steak to be well done.
Room temp meat.
Don't oil the pan; if you get as hot as you are supposed to it will can burn the oil and give and odd flavor at a minimum cause more smoke than you need. Oil the steak, which also helps hold your seasonings on. I put into a dry, but VERY well seasoned cast iron.
I use salt and pepper only, on occasion I use something called 'Complete Seasoning' out of the Hispanic aisle
My steaks stick to the pan when I throw it on. Let it sit. Do not touch it for at least a minute then gently push on the side to see if it moves. Don't ever pull/pry a steak off while its cooking it's trying to tell you something. Listen to the voices.
Now that you can move it, look underneath and see if it looks ready to flip. The first side down is almost always the best looking side so pay attention to that. Flip when ready.
I like this method for testing for doneness. The Finger Test to Check the Doneness of Meat | Simply Recipes
Important - if you like medium rare, quit cooking just before you get as there it will cook more after you take it off the heat.
Take off heat, rest it for a couple minutes. I usually do 1-1.5 lb ribeyes so I rest for about 10 minutes with a piece of foil set on top (not wrapped tightly). Sometimes I put some butter on top now.
Pre-slicing before serving kinda optional depending on size of the steak. I do on mine, usually just me and the wife but only cut enough for serving. Cut of more if second are needed but usually there are leftovers and cold steak slices very thin for leftovers (sandwiches, biscuits, etc).
Always cut against the grain and serve with the first cooked side up for presentation.
redneck joe
double post
ezbtr
well darn, buddy who was bringing steaks passed grocery store up, other couldnt make it so we all had pizza! :)
lncoop
3-4 minutes is for a thick cut of 1" or more. You will never get well done steak that is fit to eat.
Fixed that for ya, buddy.:laugh: As much as I love cast iron I prefer stainless for cooking things like steak in a pan because I like to deglaze all that goodness for a simple pan sauce. Can't do that with iron.
