81 235. just rebuilt all 3 carbs with kits folllowing shop manual and instructions in the forum. made sure linkage was correct and adjusted throttle pick up point.
1) no leaks when pumping bulb to fill bowls and motor is down. but i noticed some gas leaking out from under silencer when engine is raised for towing. normal?
2) this is my first time running an outboard on muffs. started much easier than when in water and engine seems to idle a little higher. normal?
thanks!
thanks!
