just recieved my alt. conv. kit
JoChek219
just got my alt. conv. kit and i took off my harmonic balancer and removed the stator like it said to do. My ques. is when i removed the h.balancer and stator all the magnets were on the stator, do i need to take these magnets and put them back on the h.balancer or can i put the balancer back on w/o the magnets??
Suggestions and answers are greatly apprecitated
Don S
Re: just recieved my alt. conv. kit
The stator is the inside piece, the magnets should be glued to the flywheel/front pulley (what you are calling a harmonic balancer) not the stator.
If you removed the stator, and the magnets are actually ALL still in the front pulley, then just put the pulley back on, nothing else required. Use an installer per the manual DO NOT even think about hammering the pulley back on the crankshaft.
JoChek219
when i took off the front pulley flywheel and then the stator all the magnets were with the stator, i figured they were supposed to be in the flywheel.....any suggestions for the next step, should i re glue the magnets and if so what kind of glue should i use?
Don S
No don't glue them back in. Leave them out. Put the pulley back on. Balance is the deal here not chargeing.
JoChek219
ok thanks alot Don!! phew was worried that i had more work to do ......
rodbolt
dons takes all the big hammer fun outta the job :(:(
glastron86
Did you have any trouble getting your harmonic balancer off? I was going to take my starter off, but didn't know if there was an easier way. My starter is a little difficult to get to the bottom bolt.
JoChek219
you have to use a puller, its the only way....used a bunch of washers once we bottomed out of threads... took a little while , and its hard on the hands
glastron86
I am having trouble just getting the bolt loose to get to the point of using a puller, I should have been more clear about what I was struggling with...sorry about that!
