This is Very Different than,........<br />Originally posted by chirs 86:<br /> Hi guys,<br /><br />Any, advise on why the milky oil on valve stem.<br /><br />Thanks<br />JC
This,...................<br /><br /><br />Drain the Block,+ Cap off the water jacket,...... Then,<br />Pressurize the water jacket of the block with about 15/20lbs of Air,+ Listen,...........<br />You Shouldn't hear Any air movement,...... I'm betting you Will.....<br /><br />It Sounds like a Major Over-Heat to Me......I was at lake when the engine started to heat up at full speed. I thought that it was a flow problem. I try not to go at full throttle. The engine start to get wrost. So I stop and check out the engine. When I lift the cover up. There was so much milky oil coming out from the valve cover. I was towed back.
