When the 1992 Merc 115 was on the boat I could adjust the tilt from three places on the boat. Now that I have a 1995 150 Intruder (along with another control box) installed I can only control it from the throttle and the engine itself. I want to wire up the tilt control that's located in the bow as well. Would this be done in the control box?
Question #2: Most of the time I end up having to jiggle the key to get the engine to turn over which has to be either a bad connection or loose wire in the control box. When it's acting up it just clicks as if the battery was dead. Should I order a new ignition switch? If so can someone recommend a good supplier? All I know about the control box is that it's white and has "OMC" in bold letters on the side of it.
Thanks
Thanks
