Keel Guard ?
oks
What else could i use that will work ?
i see that the gel coat is starting to
rub off from loading the boat on the
trailer .
ondarvr
Re: Keel Guard ?
If your wearing the gel coat off loading the boat on the trailer then there's something wrong with the trailer or the method used to load it. Beaching the boat is the normal cause of wear on gel coat.
Bob_VT
Re: Keel Guard ?
Is the entire weight on the keel rollers? You "might" be able to adjust the trailer bunks or rollers to lessen the weight on one spot. I agree with what ondarvr said ;)
