crabbingcake
- Joined
- Sep 24, 2017
- 4
I'm wondering if the stern end of my keelson can be repaired. Where the rudder assembly passes through the keelson, it appears to be held in place with four lag bolts. The keelson is experiencing rot and I am starting to see a slight movement in those bolts. The rot continues from the stern of the keelson forward about 13 inches. Can I remove the rudder and assembly, cut out that section of keelson, get a piece of oak the same size as I have cut out, and splice that in place to the rest of the keelson with some sort of bracing? Or, in other words, what the hell should I do?
