Re: keeping alumimium shiny
Hi sinkunit0 <br /><br />Here is what I was told when I was thinking of polishing mine. You wont need to do that part
but do use the marine grade aluminum. <br />steps:<br />1: Polish (you can skip that part)<br />2: acid etch (it will turn yellowish)<br />3: Rinse with water until clean again <br />4: Blow dry (air hose)<br />5: Spray with 4-6 coats of marine clear coat.<br />6: Wax! There is a waiting period for the clear coat to fully cure before waxing. <br /><br />Be it paint/clear coat on a car or boat your still using the wax to protect it. There are many opinions on how to do this. <br /><br />You didn't say why you wanted to put the diamond plate on the transom? For looks OK.. to support a weak transom on a fiberglass or wood boat I would not recommend it. Do the repair work.<br />Just my thoughts<br /><br />Link
