Anyone know what connections go where on the back of the key starter? Basically I have the old one hooked up but the markings are different and I don't want to connect anything wrong. It has push in choke feature. Thanks!
That looks like a Push to Choke switch (should have read OP more closely) for an outboard... Check Diagram "B" at the bottom of this link: http://www.boatfix.com/how/switch.html
I have a 1982 Johnson 175 HP OB on a 1972 Hydrodyne she flys. Can I use UncleWillies info then to rig it up. By the way there is 2 M not labeled 1 or 2 how do i know which one is Magneto or ground. Theres the bottom M that is mounted not like the others is this the ground? You guys have been a big help thanks so far!
... By the way, there are 2 M's not labeled 1 or 2 how do I know which one is Magneto or Ground. There's the bottom M that is mounted not like the others. Is this the ground? ...
