Motor is a 1975 Merc 402 40hp with Mercontrol.
I was test running the motor in the driveway on muffs. It started and ran fine then warmed up and was idling high so I wanted to make an adjustment so I shut the key off but the motor did not die. I started wiggling wires and when I pushed on the big main harness that plugs into the outside of the motor lower case it died.
But then it would not restart, no cranking, not even a click. Wiggled the same wore harness, nothing, wiggled, the Mercontrol lever in and out of gear, nothing, wiggled the wires going to the ignition, and the main harness again and it started right up. I tried to wiggle things and reproduce the problem but it never came back.
I have had instances in the past when it would not crank and I just wiggled the MerControl in and out of gear and back to neutral and it started. I'm wondering if its the safety switch or could it be something else.
Thx
Thx
