I have a Carolina skiff and want to put a kicker motor on it. How long should the shaft be ?? Can I get away with a short shaft with the bracket that raises and lowers the motor to the water. ?
Thanks , Bruce
A pic would help because you gave no info on the size and model of C/S. If possible get a long shaft even if you use an adjustable bracket, it helps to keep the power head out of the water when it gets rough.
