longshanks
- Joined
- Jun 12, 2006
- 188
It looks like I need some help in troubleshooting my fuel supply!
My main motor (90HP classic carb'd Mercury) and my kicker motor (9.9 mercury 4-stroke) are fed by a single fuel tank and fuel line that is routed through a fuel/water separating filter and then 'Y'd off into 2 lines that distribute fuel to either one motor or the other. Fuel distribution to the kicker or the main motor is switched by inline ball valves.
Lately, when I am using the kicker motor, I prime it using the inline bulb and it runs for a few minutes before running itself out of fuel. If I pump the bulb when this happens it will come back to life and run for a while longer before the same thing happens again. No problems with the main motor, and when I run the kicker off a stand-alone tank and hose it runs fine. This tells me that there is a problem with my fuel supply. I suspect that there is air entering the short portion of fuel line between the filter and the kicker motor, but I am open to suggestions about what may be causing this.
I replaced the inline fuel filter recently but there is no improvement. Could there be some sort of issue with a fuel pump?
