kicker required
magster65
I know this topic has been discussed but I need a kicker that I can lift on and off the swim grid while out cruising. The problem is it's a 26' that weighs in at a hefty 9000 lbs. I won't need to dock with it in the wind, just to fish. I'm hoping a 15 hp will do it. Do you think so?
Boatist
Re: kicker required
Magster<br />I have a 1975 15 HP kicker on a 21 foot Aluminum runabout that weighs 2800LB and it is not big enough. It does work but with wind or big swells need more power to control. My motor weight is 74 lb. I am looking at a Honda 20 HP 4 stroke but it wieghts 103 lb.
flashback
Re: kicker required
Magster, I would think it would push you along around 3 or 4 mph if you don't need to fight wind and sea..otherwise 9000 lbs is a lot of boat for 15hp... How are you planning to mount the engine to the swim platform? reason i ask is I just picked up a 7.5 honda and was thinking of using it on my boat for a kicker. Im on a small inland lake most of the time so the small engine should be adequate. I want to design a mount that is easy to take on and off as we ski with the boat and i don,t want the motor mount in the way under normal conditions.. got any Ideas? thanks.....
Jack Shellac
Re: kicker required
A 15 with a high-thrust prop might be marginally OK, but seems a little small for a boat this size. The weight and getting it on and off is going to be a tough factor in getting much larger, though.
Capn Mike
Re: kicker required
The Yamaha people tell me that their 4 stroke 9.9 high thrust is better for this than their 15 "regular-geared" motor. I've see a couple of 26' Tollys use the 9.9, but can't tell you if they are happy people or not. In my brief on-line shopping tour, I don't see that anyone even makes a 15 hp high thrust; 4S Yamaha jumps from 9.9 hp/99lbs to 25 hp/190 lbs (thats 247 Canadian ;) )<br />Honda's 15/20 hp weigh 110; their 25/30 weigh 150;<br />Johnson's 2 stroke weighs only 75 lbs, but isn't a high thrust. <br />Tohatsu/Nissan's 4s 15 is 114 lbs.; they don't appear to make a high thrust, although their gear ratio (2.15 to 1) is getting close. Someone (Yamaha?) shares the Tohatsu/Nissan block, but I can't remember who.<br />My trusty marine catalogs show various kicker brackets made for heavy 4 strokes. They offer "power assist" lifting (i.e., big springs), so you probably need to plan for that expense along with the cost of the motor.<br />I've stated before that my Yamaha 9.9 high thrust moves my boat (no more than 4200 lbs) along nicely @ hull speed @ about 1/2 throttle, even against the river currents, but won't work well in hefty winds. Frankly, I don't see that increasing kicker horsepower by 10 or 20 would do any better. <br />Let us know what your research shows!
Boatist
Re: kicker required
Magster<br />15 HP Johnson/Evinrude 74 LB has a 4 Blade high thrust prop. I have it on my 21 foot aluminum runabout. Prop makes a big different in backing but did not help that much in forward. The Honda 15/20 HP 103LB has two different 4 blade high thrust props. The New 15/20 Honda 4 stroke also vents exhaust away from the prop in reverse.
