kicker size for a Bayliner
navyinak
Does anyone know the largest size kicker I can mount on my 25 ft 1976 Bayliner Saratoga? The mount is on the fiberglass swim step, and I don't want to break the step or the mounting hardware. I found a used 18hp Mercury, and a 9.9hp Johnson, and don't know which to go with.<br /><br />Thanks.<br /><br />navyinak@yahoo.com
roscoe
Re: kicker size for a Bayliner
I wouldn't mount any motor on a swim step. <br />They are meant to hold weight pushing down, not the forward thrust of an engine. And are likely not strong enough to mount on either. <br /><br />Replace the step with a motor mounting bracket, or even a setback jackplate.
Fouled Plug
Ensign
Most of the swim step mounts I've seen are rated for 9.9 4 strokes, or 20hp 2 strokes. I would lean in the direction of the 18, as it has more oomph to combat current and winds than the 9.9 does. Nice feature for a trolling/get home engine. A buddy has a 24' Nisqually flying bridge, and his 15 hp does a good job. If the swim step is sound, it should be no problem. I think Roscoe may be picturing some flimsy teak affair, not your slab of 'glass. :D Lots of charter and pleasure guys here in SE Alaska have swim step mounted kickers. Here's a pic of a Saratoga with a kicker mount:
nburford
I agree with Fouled Plug. You may wish to consider a 4 stroke, this way you can just "T" into your fuel line. If you use a 2-stroke, you need to cary a tank on deck, oil, etc.<br />Good Luck,<br />-Nick
navyinak
Thanks guys. I ended up with at 15 hp Evinrude that I got for a steal. The boat is actually set up with a T for a 4 stroke, but I am not comfortable with that. As a Navy engineer, I want a completely separate fuel supply for my emergency system. Call me paranoid.<br /><br />Fouled plug, Where in SE Alaska are you? I am working for Admiral here in Juneau as part of his Navy Staff.
Fouled Plug
Ensign
Good plan, having individual fuel systems. They should both run through a water seperating filter, especially here in Southeast. I'm in Ketchikan, but spent a year or so in Juneau. Coho fishing out of Auke Bay should be pretty hot right about now. :)
