Kicker size
Knot Working
I have a 23' Seafox WA with a single 250hp Yamaha. I would like to fish offshore but need a kicker for peace of mind. Question is what size motor should I use with this boat. I have seen other boats in the area with as small as 8hp while others carry a 20hp. Will an 8hp do the job if propped right?<br /><br />Thanks,<br /><br />MS
D
DJ
Guest
Re: Kicker size
I have always used the 10% rule. Especially offshore.<br /><br />The kicker should be 10% of the HP of the main engine. In your case-25 hp.
phatmanmike
Re: Kicker size
and yamaha makes a SWEET 25hp, very light and nimble....get it and go on the warpath<br /><br />mikey
gator79
Re: Kicker size
no less than a 25, remember to calculate for bad weather and winds offshore. you want enough power if you are comming in against the wind.
