I purchased a 99 johnson and i am using the harness the came with it. It was set with twins on the original boat. I am using only the single<br />The kill switch has a black with yellow stripe that is not connected to anything. I hooked everything up and I can hear the choke open when I push the key in but when its turned nothing... Battery has full charge and is connected right. The tilt and trim works fine. Does this wire need A positive or nagative feed . The plug is on the top of the kill switch. <br /> James <br /><br />
