Kill Switch and Ignition Kill no workie!
jayard78
I took my new fixer upper boat out for the first time the other day and I had an issue where sometimes the ignition would not turn the motor off when I turned the key to to off position. To make things even worse, my kill switch would not work at all either. Sometimes the ignition would kill the motor but the kill switch itself never does.
One time the only way we got the motor to die was to disconnect the fuel line and wait 5 minutes. Any help appreciated.
tashasdaddy
Re: Kill Switch and Ignition Kill no workie!
black wire yellow chaser is the kill wire, sounds like short, loose connection.
