Re: Kill switch Mercontrol
Slitting into the harness and splicing into it, unless you do a very professional (solder, adhesive heat shrink, more heat shrink, rubber tape, vinyl tape ) job will almost always cause trouble in the future. Old bass boats are famous for quirky wiring caused by the scotchlock quickies.
You're much better off running 2 wires back to the control box, putting one on the kill circuit, and one on a ground screw. Use the heat to solder on terminals, and you'll never have trouble with it. Another permanent connection is to solder on an uninsulated terminal, and insulate it with a short piece of adhesive lined heat shrink.
I believe in kill switches. I've seen guys ejected from bass boats, swim back, climb back in, and go on fishing. They were sore in the morning, but they didn't get run over or stranded in the middle of the lake.
hope it helps
John
