Kill Switch
waterdog71
I have a '87 50 HP VRO, I want to install a kill switch. I have a kill switch which has 4 posts. Two marked C (coil I think)and two marked M (magneto I think). Some one told a black wire with tan stripe is the wire to splice into. But how do I connect to kill switch?
OBJ
Re: Kill Switch
Look for the black w/yellow stripe wire coming from the power pack. This is the pack kill wire. What you want is when you push the kill switch, this kill wire is routed to ground. So you would have one wire to the kill wire and the other to ground off the switch.
