Re: kill switch
J Headrick,<br /><br />Man,... you are tearin' it!<br />I've followed some of your posts and "boy-howdie", your gettin it done quick.<br /><br />To your question. Yup! you sure can. I don't have my manual infront of me so please double check your manual/ignition schematic.<br /><br />Again, check your manual. I think that your point BREAK (open) the path to ground. If your points BREAK the path to ground, tie your new switch between a good ground and the coil side of one of your set of points. Engaging the switch will tie the Lo Voltage side of the coil to ground then the coil cannot experience the di/dt (change in current with respect to time) that arrises when the circuit is opened. It is the di/dt that induces the voltage in the secondary,..and,...no di/dt, No SPark, No run.<br /><br />At the rate your going, you'll have it done before I finish typing this.<br /><br />Good Luck<br />HAVE FUN!<br /><br />EDIT> don't tie both sets of points to the same pole on a switch. That would short the primaries of the coils together. It might still run like that but I wouldn't risk it. Rather, try killing it by wiring one set of points thru the switch.
