King Cobra 351 5.8 1992 Spitfire Ignition Conversion
brbeckwith
I've got the spitfire eem ignition system, and am bypassing it with the DUI distributor ignition system. I'm not sure where to pull the tach from for the new distributor. Does anyone know if the timing ring sensor uses the eem module to convert to pulse for tach? What options do I have for installing a tach sensor that uses a pulse signal for the DUI system. Just need a tach wire to pull from. Please help!
brbeckwith
I guess the DUI ignition distributor system generates its own signal? The tach wire is sending a pulse signal to the guage?
