I have a 2003 Four Winns 268 Vista with a 350 Mercruiser BravoIII. I can hear a slight knocking noise coming from the out drive when its idling. You can not hear the noise in the engine compartment. Also, when I push the throttle the boat accelerates fine until about 2400 RPMs then it bogs a little bit and does not acclerate anymore. The motor sounds good and there doesn't seem to be anything leaking. The lower unit fluid is fine as well. Any thoughts of what this could be?
