cruising along and all of a sudden i hear a knocking in my motor so i stopped. then it went away. 10 min later starts knocking again so i stopped again this time it kept up so i anchored and took the valve covers off. I thought it was a push rod. it wasnt. started it up agian and while at idol no noise. start bringing up the rpms and theres the knocking again. thought it was a rod however i ended up driving over 3 hours to get home at 5 mph. IF it was a rod would it not have went already. i can let the boat cool for an hour and when i start it it will idol fine but as soon as i race it the knock comes back. rod going bad??? now the kicker, smoke pouring out of the breather(blow by)... now if it were a rod that wouldnt cause massive smoke out of the breather. no smoke coming out of the exhaust. (no more then usual) so what can it be. I just had the intake manifold off and chaged the gasket. could i have dropped something in the motor causing this. the boat runs great just a banging from the motor under load or if you race it for a minute. the hotter the engine gets the worse it is. cant put my finger on it. sounds like it has to be more then one thing. however the boat was running great up intil then. getting great oil pressure. not running hot. somebody help. when i took the valve covers off and turned the motor over smoke puffed out of the motor where the push rods go in. ford 460 1987 7.5
