knots per hour
External Combustion
Re: knots per hour
There is no term of "knots per hour", just simply knots. When speed was determined by a chip log which was just a float designed to not move through the water, the line attached to it had knots tied into it at set intervals. When the chip log was thrown over the stern of the vessel and stabilized in the water the line attached to it was allowed to run out of the spool that held it. At discrete intervals, a knot was tied to measure the distance. A timepiece, usually a sand dial was used to measure the time that the log was in the water spooling out the, line. The speed was measured in the amount of knots that went overboard. The math was knots per time thus already knots per hour and reported as knots.
I still use a chip log occasionally, and it is very accurate at low speeds.
Check out Chapman's Piloting. It has a section and pictures of the old chip log.
chicknwing
Re: knots per hour
Wow, this is what i love about this forum. What a great question and a superb answer! :D
25thmustang
Re: knots per hour
External has it right... very primitive way, but when you have nothing else I'm sure it worked. Now a days there is a knot to mph conversion, but knots sounds much cooler :D.
DavidD
Re: knots per hour
Is the conversion 1 knot = 1.3 mph?
twag4
Re: knots per hour
Knots is short for nautical miles per hour nowadays. They equal 1.15 statute miles per hour. Your car speed is statute miles per hour. One nautical mile is equal to 1.15 statute miles.
