Kodiac Brake Pads
bruceb58
Anybody have part numbers for their favorite Kodiak replacement brake pads? I may need to replace mine this coming year. Anyone use ceramic?
Go Aweigh2452
Re: Kodiak Brake Pads
Look at the number of lug nuts and that is all you will need. I order my brake parts for my trailer from:
http://www.trailerpartsdepot.com/index.asp
They are probably Titan brand... 90% of all trailer brake parts are... make sure the metal parts are "E-coated"
If still not sure try calling Kodiak and asking...
dingbat
Per the manual:
Pad #D-289 for model #225 same pad as used on 1980-1990 Buick Skylark- Front
Pad #MD-215 semi-metalic for model #250 same pad as used on 1983-1995 Buick Century H/D - front
Pad #MD-459 for model #338 same pad as used on K30, K3500 $WD 1992-2001 Dual rear
I have ceramic pads on mine. 3 years so far so good
bruceb58
Found some Semi Metallic on sale for little less than $9/axle at Rockauto for the model #225.
Thanks for the help.
