slicksboat
- Joined
- Mar 10, 2011
- 26
ok i got a 92 force 125 l drive i was useing a crap load of gas so i tried to mess with the set srews
now first question correct me if im wrong the fuel mixture screw is brass looking with a spring on each carb
2 what is the short white plastic screws right next to the brass ones if loose it rattles out
3 whats my staring position of the screws for full i have read 1 1/4 out then in a 1/8 at a time till stalls the back out 1/8 at a time
4 i messed with my timing trying to lower ides cause it was at 1000 in gear soooo when i do timing am i suppossed to unhook fuel so it wont start and set at 30deg while cranking wot
