Re: L.E.D. Lights???
I was going to say the same thing amiga, snow and boats are only an issue for the marine rescue boys heading out for some yahoo that ignores the
THIN ICE warnings AND personally i think letting someone that stupid be absorbed by the Darwinian Paradigm is just common sense, but there I go being insensitive .... (of course, once thawed out they should be slapped twice, shot with sh!t and arrested for stinkin ....<br /><br />but thats just my take!<br /><br />onward ...<br /><br />Rays Rules for Good Lighting<br /><br />1 all connections soldered, hit with "liquid lectrical tape" THEN siliconed<br /><br />2 Ground wires to all lights, tapped into ground feed on connector<br /><br />3 remove bulbs, clean out socket with wire battery terminal brush, shot of WD 40, clean bulb bases, shot of WD40<br /><br />4 To stop annoying "fast flash" and other maladies, I go to radio shack, get three heavy duty 12v relays, and run a 30 amp fused wire back the trunk - mount the relays to a board and let tail run on one, left and right on the other two<br /><br />that way all the tail and flash/brake lights do is supply control voltage to the relays, the trunk feed run from the battery supplies the lighting voltage<br /><br />Schematic can prolly whip up a diagram in ten seconds flat, but trust me, youll figure it out<br /><br />THEN you can hook up additional lights, including rear facing externally switched foglights, so backing into a dark ramp for some night fishing isnt a problem, and I hardwired an outdoor 12 volt plug to hang a 12 volt trouble light to let me see what I am doing, no flashlights needed<br /><br />and if you have to change a flat tire at 330 AM
you simply plug it in, good to go!
