L/U and W/P reinstall on 18hp Evinrude ??
whitejd12
In the picture, 2013-07-20 10.14.26.jpg is there any kind of gasket between L/U and exhaust housing when putting back together. Didn't see one on parts diagram. Should I use Permatex or something, or nothing.
Also, do I use any knd of sealer on the W/P impeller plate when reinstalling new W/P?
Is there anything else I need to lub or seal when putting L/U and gearcase back together?
Thanks a lot.
Jeff
Daviet
Re: L/U and W/P reinstall on 18hp Evinrude ??
There is not a gasket between the housings.
You can use sealer on the plate on the bottom of the pump, I normally don't.
whitejd12
Awesome, thanks!
whitejd12
BTW....What is this little black magnet looking thing in the following pics? 2013-07-20 12.31.18.jpg2013-07-20 12.31.32.jpg It sits in a groove in the back, lower section of the gearcase housing.
Daviet
If I remember correctly, it is a magnet to capture any metal fragments in the lower unit.
