L/u on a 1977 mariner wont go all the way in
Hitnmiss
I have a 77 mariner 6 cyl 115 that the lower unit is giving me fits .eerything is lineig up water tube,itll go up and still have about a inch left i cant figure it out,oh its another lower unit its a arly 80s .
jimmbo
Have you tried rotating the flywheel as you are pushing it on? Since you are trying to install a different LU, did you check to see if the splines are the same as the old one?What about the shift shaft?
Chris1956
The gearcases can be tight. Make sure the driveshaft splines are mated, and the shiftshaft splines are mated and then wiggle it into place. Put a nut on the front stud and tighten with fingers only. Now wiggle until you can thread a nut onto next set of studs and wiggle some more, tightening nuts with fingers only, until the gearcase mates with the midsection.
jimmbo
Clean the splines and lightly lube them. DO NOT put any grease on the end of the shaft as that can cause problems
